8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 15 New Guy | | New Guy Joined: Mar 2008 Posts: 15 | Will a reproduction fulton sunvisor for a 53 truck fit a 54 five window??? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The fulton's were basically a universal visor. They could be adjusted to fit a wide range of vehicles. With a little help they can fit about anything of that era. This site can help you understand how they go together.
| | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | It may not follow the contour of the cab since the 54's have the one piece windshield. | | | | | Joined: Mar 2008 Posts: 27 Apprentice | | Apprentice Joined: Mar 2008 Posts: 27 | I know a visor from a 47 chevy fleet master can be adjusted to fit a 1950 chevy 3100. It does seem to be very adaptable, when I cleaned mine up I replaced the screws that go into the adjusting arms the "wings" of the visor slide into, the old screws where aluminum and twisted off after being in the same position for 61 years on the fleet master. The brass screws that attach the center of the visor to your window clean up fairly easy and help keep the original look to the visor. A side note, I've found the original fulton visor had a tendency to "buckle" about half way along the front edge of the visors "wings" if you tried to adjust them after you have attached the center pieces. Also, be sure to mold ( as best you can ) the curve of the support arms where they screw into your door frames, otherwise it will rub when you open and close your doors. I used a body molding die and body hammer to curve mine. Be sure to do this prior to any painting you do. Hope this helps.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | T-Rex,
The '53 has a two piece windshield. The visor uses the center divider as a attachment point. The '54 uses a single piece windshield. The visor must use a bracket that attaches to the top of the cab.
I'm pretty sure the reproduction visor will have no 'bracketry' to allow it to attach to the cab for the '54 and '55/1st applications.
I think this is how it works.
Stuart | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | there are different brackets available.i have an original fulton visor(installment is aways down the road) mine came with the center bracket that attaches to the cowl vs. the divider strip of the winshield.maybe this would work for you.there is a guy on e-bay(member name is loupeestuff) sorry dont know how to do a link yet .he sells lots of fulton parts and has lots of info.i bought a different set of dogbone brackets from him.goodguy to deal with.maybe he could help.........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | So, the question now is: has anyone put a 47-53 Fulton Sunvisor on a 54/55 truck cab? Pictures of the attachment points would be nice to see.
I have seen very poorly installed Fulton visors on 54/55 cabs (as Stuart describes - with side brackets attached to the roof, not inside the "drip rail"). One visor was from a 53/54 Chevy car and might have used the car's attachment brackets.
Tim | | | | | Joined: Mar 2008 Posts: 15 New Guy | | New Guy Joined: Mar 2008 Posts: 15 | Thanks to everyone for the replies. I guess I'll have to do some scrounging to find what I need. | | |
