1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | Bought some parts from a monster GMC truck today. Model ACRF not sure about the F SN# 430 Rated 126 hp @2400 rpm. Year 41 -42? Max GVW 27,500 Max GVW combined 40,000. Big 6 everything was on the opposite side of where one normally sees it. The tranny was enormous as big as a normal 6 cylinder engine. What size engine is in this truck? What type of transmission is being used? It was a GMC with a General fire truck body. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Lockland41, there should be some numbers after the letters,which would help identify what you are looking at. Just using engine horsepower as an identifier, I would guess it is a 360 c.i.d., that engine was used in the AC 700 series. The "F" may designate a fire truck chassis, hope that helps. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | GMC made up to a 500 something c.i. 6 cylinder gas engine. They also had 4 and 6-71 diesels.
I love those AC models. I either want my next truck to be an AC model or cannonball with a 6-71... Oohhh yeaahhh! Now youve got me drooling on the key board. And by the way, why dont I see pics????
The A indicates 39 and up. The C indicates conventional cab. R indicates Tractor. My book only shows R and W as being the fourth letter, so Im not completly sure what it is. Being that its a Tractor model, its a 520 series or bigger with a 308 6 cyl and a Clark transmission as being the stock drivetrain.
You better get some pics next time!
Jeff | | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | Jeff, Sorry I didn't take pictures. I think the fellow is going to lay the balance of this beast to rest. The Chinese have a strong taste for scrap metal. Sad. It was one big heavy truck. Joe | | |
