5 members (Johnny Rib, Otto Skorzeny, dwreills, Wickedbass, TooMany2count), 114 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#391282 03/21/2008 11:46 PM
I
I Offline
I have more holes in this bus than Tony Montana. ( screw holes ) The previous owner liked using screws to hang things etc. Theres a hole from the old heater, screw holes, and I recently removed the propane heater. The insulation almost looks like asbestos,...ewwww. So I was wondering if its worth to drill out the panel rivets,...rip the fun stuff out, re insulate or not. Theres an old school mechanic on the property I live at who says don,t do it, I don,t need to etc. I live in the great white north so duct taping these holes off are not an option. I,d like to pull the panels,...insulate it my way and re install the panels,...fill the holes and paint away. Any advice bolters ? Thanx Guys ! Cheerz !
you shouldn't need to pull any outside skin to insulate, and I can tell ya removing and replacing hundreds of rivets takes special tools and LOTS of time
if it's inside panels that are metal and riveted, they'll sweat if you leave them, you need to get rid of them or insulate on top of them and cover with wood panels - there should be NO direct metal contact from outside skin to interior finish .... random screw holes in metal can be filled with rivets
get yerself by here and talk bus!
Moderated by  ndkid275, Phak1
