3 members (tclederman, Otto Skorzeny, 1 invisible), 116 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#390234 03/19/2008 8:38 PM
I tried some searches for this information, but didn't come up with anything. I have a 1951 6400. I have beautiful fenders, except they are rusted badly for about 6 inches where the fender meets the cab. I realize the fenders of the big bolts and smaller trucks are different, but what about the mounting surface where the fender mates to the cab? What I was hoping I can do is cut out that part of a small truck fender and patch my big fenders. Has anyone out there done this? Are the curves, profile, etc.. the same in that location? I don't have any small fenders laying around to see. Thanks in advance for the help.
1949 Studebaker 2R16A
1961 Chevrolet Impala
1968 Chevrolet Corvette Roadster
1971 C10
H.I. #390249 03/19/2008 9:10 PM
3B Offline
Hy H.I., as the cabs are all the same I would think a "patch panel" from a small truck could be made to work fairly well, you might have to tweak it a bit but it should be doable, hope that helps.
3B #390255 03/19/2008 9:21 PM
The hoods and fenders are longer by several inches on the big trucks. But it may work. Let us know what you do and take pictures for us!
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #390274 03/19/2008 10:28 PM
I do know that running boards have a taller "skirt" on the big trucks than the small trucks, thus the cab down to running board measurement is different for big and small trucks.
This could be a factor depending on how much of the patch panel you need to use, as the fender lines up with both cab and running board.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #390312 03/19/2008 11:53 PM
All good points guys, and I appreciate it. I understand what you're saying Grigg, the part of the fender below the cab that stops even with the bottom of the running board is longer and bigger. I hadn't thought of that until you said something. I'll study on it, but if the contour is the same, I feel I can make it work. I will take pictures with I start it. I'd love to find a couple of good big bolt fenders, but in humid, salty, Florida they are hard to find.
1971 C10
