7 members (Gdads51, Otto Skorzeny, TexasA&M48Truck, 5cameo8, TUTS 59, Youngin' Tut 59, Gray_Ghost),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,116 Posts1,056,599 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | Hey does any one know how to remove the rear pinion seal? Do you just loosen the big nut, pull the universal off and take the dust cover off. And then what? Do I need special tools? Any tricks? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike Shepard, depending on the size of the rear axle, it can be a fairly simple. As you describe remove the yoke, the cover may come with it, then pry out the old seal and install the new one. Check the yokes seal surface for grooves, if it is badly worn you can probably find a "speedi-sleeve" to repair it, hope that helps. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Where do you find pinion seals for the old beaters? I personally have had some trouble finding one for the 54 HO72. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it's a 1/2 ton you pull the yoke & pry out the seal like 3B stated. If it,s a larger truck after you pull the yoke & the flange that holds the seal. On a 1/2 ton mark the position of the nut compared to the shaft & tighten it back to the same place. If it turns too easy put some thread locker on it. On a larger truck put the flange on so you have acsess to the cotter pin hole. Tighten the nut very tight & go a little further to line up the cotter pin hole. Any parts store ought to be able to get the seal for you. I can look up the part number tomorrow but maybe another bolter will come up with it before then. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | If its not a 1/2 ton truck, try National Seal # 41130N. It measures 2.598" x 3.481" x 0.50"
