2 members (BC59, Bill Hanlon),
152
Mod | | | Forums66 Topics128,088 Posts1,056,109 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | I have looked over the tech tip regarding valve adjustment, and have searched the previous posts, but I cannot find an answer to this question. Let me first state that the last time I tried doing this on my '59, I managed to burn a valve. Now I understand what the tech tip states, but suppose you are a little nervous and want to do this slowly, carefully, and are scared to death of setting too tight and burning valves. So (finally) my question is this; If I take the adjustment cylinder by cylinder (hot of course) can I presume that if, say on cylinder #1, the exhaust valve is fully open, that I could set the #1 intake at that point? Is it correct to presume if one valve is on the high point of a lobe that the other valve must be fully closed, and thus on the low point of the cam lobe? Have mercy. Keep the tomatoes and empty beer cans down to a minimum, please!
Richard 58 3104
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I would not make such a presumption. The best way I've found is method #3 in the tech tip.
"#3 General (Engine NOT running) -- "I have a trick I use every day at work to set valves on inline 6 cyl. motors. Chevrolet and John Deere firing orders are the same: 153624. Set the motor to fire on #1. Set the lash on 1E, 1I, 2I, 3E, 4I and 5E. Then rotate crankshaft one revolution. #6 should be in firing position. Set lash on #6E, 6I, 5I, 4E, 3I, 2E. Your valves are all set, and it only took about 5 or 10 minutes. Remember exhaust valves are on the ends of the head, and they look different than intake valves, so it is easy to identify the valves for cyls. 2,3,4,5. I hope this will help someone. Again, thank you!"
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Easiest way is to set the engine by the TDC mark on the flywheel. Now either both #1 valves are closed or both #6 valves are closed. I like remembering it this way;
You have 12 valves starting #1 cylinder with both valves closed (all the way up);
Adjust valves 1,2,3,5,7,9. Turn the engine over 1 revolution so the TDC marks is on the flywheel again. Both #6 valves should be closed. Starting in reverse, adjust valve 12,11,10,8,6,4. All done.
I think thats the easiest method of remembering. So long as you start on the end of the engine where both valves are closed and the flywheels on TDC, either #1 or #6. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Oops, you didnt mention whether or not it was a I6 or V8??? | | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | Sorry, Rusted Nuts, its a 235!
I guess I will go ahead and give it a try. Just a little on the nervous side.
Richard 58 3104
