Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#388144 03/15/2008 1:01 AM
i got a 62 GMC 4000 with 6 lug wheels and a two speed rear end. is it supposed to have two different kinds of axle shafts? on one side it has the kind where the axle bolts in and the other side is the kind that a cover bolts over the axle shaft.
47chevy6400 #388186 03/15/2008 3:00 AM
I would imagine not. Do the hubs appear to be the same? They might be a little different in size and that could tell you for sure. Someone would have had to swap the hubs, because the one with the cover has a tooth setup that spins the hub and wheel. I dont know which ones would be original to that truck, but I really cant see why GM would mix the two axle types.
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #388209 03/15/2008 3:51 AM
the hubs look the same besides having a different bolt pattern for the axle. Which axle setup is better?
47chevy6400 #388247 03/15/2008 6:07 AM
My preference is to have the kind that bolts to the hub. Just unbolt and pull the axle. The toothed type usually has me looking all over for the right sized bolt to screw into the center of the axle to have something to pull on. If you decide to swap youll need to find another hub to match the axles bolt up pattern. I can get some pics of what Im talking about if you want.
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #388280 03/15/2008 1:24 PM
Better depends on your intended use. Just for puttering around town, the bolt in axles work fine. But for heavy duty max payload work the splined axles can take more of a beating.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Freq2002 #388321 03/15/2008 4:23 PM
Just curious, but how does that work???
My 1953 Chevrolet
1947.1 Gallery
rustednuts #388819 03/16/2008 7:07 PM
I'm thinking if it isn't broke why change it, nobody will be able to see both sides at once:}
