| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | looking at a 46 chevy 1/2 ton with an all original 216 thats not stuck in it just sat for YEARS... everything still hooked up 6volt, any pointers on getting it started and running again??? thinking flush out radiator and block rebuild carb fluch and clean fuel tank and get new tune up parts new battery and fire it up right????? whats the longest sat idle 216 anyone has got running again thats usable  | | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | These old engines can last virtually forever it seems. My sat for 17 years before I dropped in about 100 bucks and drove it of the shed it was sitting in. My advice is this rebuild the entire fuel system. Blow out the fuel lines, rebuild the carb, clean repair replace the fuel pump, pull the gas tank clean it and seal it (I didn't do this and went through a heck of a tough time keeping the gunk from the tank from clogging the system do it sooner then later). When this done before you drive it away check the brakes if it has set awhile they will need work. All told it is an afternoons work and little else. Also I would recomend changing the oil, coolant fluid, and flush the raditor. Eventually a rebuild should be consider but if the vehicle was parked with low miles this doesn't need to be to soon unless it is to become a daily driver. | | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | Oh by clean repair replace the fuel pump I mean choose one based on its current condition. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I would also pull the brakes apart and make sure the wheel cylinders are free and will return. If they are not, pressure from the master cylinder could cause them to freeze up in the applied position, making drum removal a real problem.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Mine sat about 20 years. Get rid of ALL traces of old gas. Put fresh oil in it & fire it up. You'll prolly haveta go through the carb.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | before taking up time doing the gas tank/line thing why not drop a line into a gallon container/jug and go from there. If it runs ok then the gas tank cleaning will be a much more joyful chore. | | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | My red '42 has not been started in about 20 years also. That is one of the many things that I want to get accomplished this spring or summer 2008.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Swing by your local lawnmower shop and pick up a plastic tank from a riding mower. A gas tank with 20 years of gunk is going to be a bear to get clean......and the mower tank can be hung up on the firewall with enough gas to get all the preliminary stuff finished and even works for a cruise around the block.
When I go to check out a project vehicle I carry the little tank to verify that it was "running when I parked it."
Dave | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I bought a 40 from my brother in law that had set for 36 years. It turned right over & i got it running like Achip said. These old engines had cast iron pistons & they didn,t corrode to the cyl. walls like aluminum ones do. It mostly depends on the climate conditions & where it is stored. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Dave, That's a great idea with the lawnmower tank. There's a lawnmower graveyard I frequent in the spring. Think I'll see if I can find one with a shutoff. Dan | | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | this 41 truck with the 216 i picked up was sitting for 21 years and was put away with a bent rod and cracked rocker........i picked it up......rolled it in the shop......put a new fuel pump on it...new lines from fuel pump to carb....had a old beer bottle put some aviation fuel in it and sat it down next to the fuel pump.....turned the motor over by hand.......disconnected radiator hoses........primed the carb........started in 2 seconds and idled in 20 seconds.......and that was with the bent push rod and cracked rocker with a frozen exhaust valve........i now call the truck...."peanut".......you cant kill these old girls............ | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | my suburban sat since 1968 and i got it started in 2003. so after 35 i disconected the fuel line to the gas tank and hook one up to a gas can, put a 12 volt battery and coil and it started. then i took out the oil pan plug and let the oil drain for a week. and put new oil. the gas tank need to be replaced. i will be cruisin it tommarrow | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It was about 10 years for mine. When it started it was one of the sweetest sounds that I ever heard!
These old sixes like lots of choke to get up and running. When you are trying to get it going, hearing the starter speed up means it is getting a little help from the motor! It will probably do that a bit and then catch. Make sure that you have a bit of throttle too. Normally the cam on the choke link will supply that. | | |
