3 members (dt235sd, BC59, 1 invisible),
94
Mod | | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 20 | hello to all here is a old 5 window GMC 5 ton series 640 will be heading in the shredder,HAS 2 large hoods that opens from the sides, IT has a VERY LARGE 6 cylinder eNGINE with 2 carburetors and large Exhauat manifold about4 inches thick, Has air brakes Complete drivetrain, CAB is junk. it is in a old salvage yard which will be cleared out THere are other large heavy trucks also I dont know nothing about the condition of motor or trans just fact it has been sitting for long time thanks Also about 1957 Gmc Cabover large series,will be crushed shortly dont know nothing of it,just in the woods, Also have old early 50,s CHEVY 4 door cab on a logging crane,it is like to cabs welded together on backsides,but it is manufactured that way and has 2 control panels to operate the 2 cranes,Selling only sheet metal,decent body,crane will be going in shredder.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | More than likely a 640 series. No such thing, as a 460 series. There was a 400, 450, & 470. 520-650 series, had the hoods like you describe. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | This is a 660. Does it look like this ?
Bruce | | | | | Joined: Jun 2007 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 20 | Hello It does not look like 660 series,this truck is not a Cabover,IT appears to be a large Rig as it has Air brakes. I will be there today ad will take some pictures. along with some others. The whole yard will be crushed out. As scrap metal is high, thanks | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Are you sure it's not a V-12? The only 2-carb GMC's I can remember were the 502 cubic inch 12-cylinders, IMHO.
OOPS! I just noticed the year! Those big inline 6's were used in the road tractors in the late 40's and early 50's. My uncle owned one that he used towing the big boats he repaired, with a lowboy trailer. Nothing much will interchange between them and the 216/235 engines. Jerry
| | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | ranchojuan, I have a '51 640 and need a lower right hand engine cover, the one just under the folding hood. Are you willing to wrench one off and I'll pay. Need to see some pictures. Rick
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Mar 2008 Posts: 1 New Guy | | New Guy Joined: Mar 2008 Posts: 1 | I am looking for the same type folding hood for a 58 630. Any leads or help would be appreciated. | | |
