0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I've been keeping an eye on this adapter plate I'm thinking of getting one to put a 292 in a 1940 1/2 or 3/4 ton. What are my bell housing options behind a 292 and what transmission options does this give me? I'm thinking of welding on a bracket to hang the clutch and brake pedals onto the bell housing. Just can't figure out if that's an option for a later model bell housing. | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | Just a novice, but I have a 292 in my COE with a sm420, I have been told several v8's used the same bell housing, so I would guess you would have plenty of options. Someone will be along who knows for sure Iam sure, good luck with yours, Tom. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | All the chevy I6 engines and V8's have the same bellhousing bolt pattern from about 63 on up. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Greg, That is awesome. It will do exactly what you think it will do. You will be able to bolt up most Muncie and saginaw transmissions to that plate. Muncies like the sm320, sm420, rockcrusher, etc. You would also be able to bolt up a T-5 with a little modification, but may be a little light behind a 292. Another great choice would be the GM version of the A833, but you would likely have to bore the bellhousing out to 5.125, or turn the bearing retainer down to 4.686 inches. I'm not sure of the welding thing either, but there are ways around that for mounting pedals.
John | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you do not need an adapter behind a 292 to a T5. it should bolt directly to your newer style bellhousing (any V8 one) w/ the larger hole. a 292 has two offset mid / side motor mounts and if those are strong enough and made short, offer great support. the T5 has a rear stock S-10 rubber mount and those three should work. the later (larger hole) bellhousing centers the tranny & bolts directly to the T5 in my case. the T5 holes must be re-drilled to 1/2'' holes. I use grade 8 bolts everywhere. the sm420 has a smaller tranny hole. http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=DSC00367.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=579990-R1-016-6A.jpgw/ this being said I do not know 40's trucks and frames. this may be what the doctor ordered ?????
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The only thing I question is that the front bearing retainer does not look like it sticks out of the adapter enough to pilot in the bellhousing. What keeps the transmission inline with the crank?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | On closer inspection... How do you bolt the bellhousing to the frame? Do you need to have the transmission bolted up to sandwhich the adapter? | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | It looks like you bolt the adapter between the bell housing and the transmission.
Basically what I think it does is add the lower mount points that were removed on the later bell housings.
Seems to be a real simple idea and maybe worth the $90 just to try it out.
I'm not sure about the bearing retainer. It would be a a 1/4 inch shorter due to the thickness of the plate. | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I've thought about using one to put a 292 in my '49, It looks like a good alternative to replacing the early x-members when updating to a late inline or V8. It should work in the pre-AD trucks too if you updated from the earlier 'crash box' and 3 speed tranmisions.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
