2 members (Cletus1950, 1955 1 Series), 93 guests, and 3 robots.
Topics128,128
Posts1,056,666
Members48,450
#384653 03/07/2008 5:35 AM
I have a TCI mustang II kit I am installing, for those who have done it where did you weld your boxing plates? inside the frame rails so it is flush or to the outside edges of the frame rail? I saw an article somewhere where someone had done it with step by step pics but can't seem to find it
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
I put in a same unit in my 37 chevy pickup and I boxed it to the outside edge, then ground the welds smooth. You will find that the cross member will fit tighter this way. If you box on the inside you will have to trim the boxing plates so they will fit flush. It probly tells you in like step 5 or 6 that you will need to cut a C notch in the frame to have clearance for the steering rack, don't worry it's easy just take your time and make sure your measurements are right before you finish welding every thing up.
37 is right, the plate should fit flush with the frame rail.
~Jim
did you tilt the front of your crossmember up in the front any? I called TCI and they recomended angling the front up 1 to 3 degrees to compensate for the rake of the frame front to rear. this is so the the tie rods stay paralel to the lower control arms. thet also said when they install them they actually put a thin sawblade between the boxing plate and the edge of the frame as a spacer when they tack it in place. then they are able to fill the gap created with weld. any thoughts on this?
OK, the more I think about it (it's been almost 2 years) my Heidt's came with the geometry built in. In other words I didn't have to make any adjustments.
~Jim
1 Offline
"my Heidt's came with the geometry built in ALSO. I didn't have to make any adjustments AT ALL." grin
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
50ADRod:
This may be the write up you were looking for? This is for Task Force, but may be helpful...
http://www.webrodder.com/article.php?AID=420&SID=16
http://www.webrodder.com/article.php?AID=421&SID=16
R-Bo
1966 GMC 305V6 in the family
No I didn't tilt the crossmember and the tierods are paralel to the lower A arms. I've built dirt track cars for 28 years, and this is the 3rd street rod I've done ( 63 chevy stepside and a 56 chevy post) and I have never had to tilt the cross member.
I used the TCI and didn't have to tilt the crossmember either!!!
