| | | Forums66 Topics128,022 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 43 Junior Member | | Junior Member Joined: Jan 2004 Posts: 43 | Here's a question: Has anyone or would anyone use a "gear splitter" in their 1/2 ton truck? A friend just gave me a 1985 SM465 transmission from a 1 ton truck he once had and will give me the gear splitter, stick, etc. soon. This unit sits between the bell housing and the transmission. I know the SM 465 will fit behind my L6 with some machining of the bell housing and bearing retainer, but I will probably use the original SM 420 that came installed as the splitter will fit it too. I have already rebuilt my rear end including new 3:38 gears. Is this worth doing? I thought it might be kinda cool. I still have a Saginaw 4 spd on the back burner too. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Haven't put a second tranny on a 1/2 ton, but I have driven a lot of bigger trucks with them.
First, how far will this move the 4 speed aft? Your gearshift will move back with it, might require bending to clear the seat. With 3.38 gears, and an o.d., your highway rpm will be pretty low. I don't know what engine you have, but you will be below the power band of most sixes. I would first build without the splitter, and see if I liked it.
Fred 52 3600 69 C-10
