2 members (2 invisible), 84 guests, and 6 robots.
Topics128,266
Posts1,058,368
Members48,485
#386978 03/12/2008 3:43 AM
Have a '66 283 stock motor. I don't know if I made a mistake but I have a new radiator with inlet hose diameter larger than my pipe and short hoses that go to the thermostat housing (1 1/2").
The question is: I can connect the hose and pipe to the thermo housing but not the radiator tank because it will not quite stretch over it. What should I do? I hate to eliminate the pipe because then it won't look stock. Is there some reducer that can go on the radiator?
sovagary
GS
Gary,
You can buy universal flexible hoses with different end ID's, check at your local quality, real parts store and give them the length needed plus the ID of each end.
Stuart
i'm having a hard time trying to find a bottom hose of '''''anything'''' to fit my stock radiator w/ a 292 motor??
Hummmmm
i'll keep lookin'
Jim & Caroline
Gary,
I don't know the sizes you're dealing with but NAPA has items #735-2891 which is a 1 1/4" X 1 1/2" adapter and item # 735-2892 which is a 1 3/4" X 2" adapter.
Stuart
Thanks for steering me in the right direction.
Gary
GS
