1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Have a '66 283 stock motor. I don't know if I made a mistake but I have a new radiator with inlet hose diameter larger than my pipe and short hoses that go to the thermostat housing (1 1/2"). The question is: I can connect the hose and pipe to the thermo housing but not the radiator tank because it will not quite stretch over it. What should I do? I hate to eliminate the pipe because then it won't look stock. Is there some reducer that can go on the radiator? Thanks, sovagary
GS
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Gary,
You can buy universal flexible hoses with different end ID's, check at your local quality, real parts store and give them the length needed plus the ID of each end.
Stuart | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i'm having a hard time trying to find a bottom hose of '''''anything'''' to fit my stock radiator w/ a 292 motor??
Hummmmm
i'll keep lookin'
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
I don't know the sizes you're dealing with but NAPA has items #735-2891 which is a 1 1/4" X 1 1/2" adapter and item # 735-2892 which is a 1 3/4" X 2" adapter.
Stuart | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Thanks for steering me in the right direction.
Gary
GS
