0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I've got a 1950's 261 cid 6 cyl. Rochester B carb, if it sits for more than a day or two the sight glass fuel filter in front of the carb is dry (fills in less than 10 seconds of cranking) even with full choke it won't start unless I pour gas down the throat of the carb...it will restart ok for 2-3 hours later, then after that I have to do the priming thing again....Carb has fresh rebuild/needle/seat/float, ?????float level low????? | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I am no carb expert, but I would say your fuel bowl is not full. That is one of its purposes. Unless it has a leak and it all drains out while sitting for a while.
On cold days where I go a week with out starting, it takes a few cranks to get things going.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Your fuel pump has two - one way valves in it. It's possible that the one preventing backflow has partially failed and, while still allowing the pump to pump fuel, is allowing the fuel to siphon back out of the carb when the engine is shut off. Just a thought.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check your accel. pump. Look down the throat of the carb & work the throttle starting from a closed position. You should see a squirt of gas going in each time. The float level may be low also. If the accel. pump is working pump it a few times when starting after setting. That is the same as pouring gas down the throat. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Tiny's probably right. I'm having a similar problem, and I've got a rusty tank. I think I've some rust in my pump - Maybe you picked up debris from the tank? | | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | your problem is a leaky fuel pump.........ive had the same problem on 3 of my antique autos......i put a fuel pump kit in each one from jim carters and they all hold prime now........and one auto a 1941 ford still has the original fuel pump that has never been touched......im looking for it to happen soon after 67 years......... | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Okay. I'm not an expert, but I don't see how the fuel can siphon out of the Rochester Carb normally found on the older 235s and 261s. Where the fuel goes into the carb is on the top of the carb. If the float is up, the seat would be closed, if is open because of low fuel level in the carb, air would enter the fuel line instead of fuel.
Most likely culprit on loosing fuel I would think would be the carb leaking somewhere and emptying out, or the fuel evaporating out of the bowl after it sits a while.
Also, if there is supposed to be a check valve in the carb for the accelator pump it could have been left out on the rebuild and not pumping the fuel into the manifold.
I don't ever remember seeing the glass sediment bowl on my truck completely full, yet the truck runs fine. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Granted it wouldn't syphon out of the bowl but it would the line from the carb to the pump. Add to that heat related percolation & evaporation of the gas in the bowl and you have the symptoms he described.
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | Fill the carb up and get the truck running, then pull the carb off and set in on the bench and watch it for the three or four hours. If it leaks out, tear it apart and find out why. If there is no leak, then the fuel is evaporating out due to heat, a heat spacer can help this. Check the fuel pump for the check valves, your fuel line should never dry out if the pump is good.
Joe | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I'll Give it a try on removing the carb, have to recheck the float level anyway.... | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Had the same problem when I had a single Roch "B" on my 261. Always had to prime it with gas or use "Nitro" in the rattle can. When I changed to my dual Holley Webers I thought the problem would go away but even with an electric choke, if it sits for a couple of weeks, I need to pump the pedal several times to get it started. Not a real problem but it still give me the impression that the fuel is evaporating in the bowls after sitting a long time. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Found the problem.....Gee I am a Dumb As$... the spring which wraps around the choke shaft came off....I apply the choke and the shaft moves, not the plate.... reinstalled and works fine now....Shoulda took off the oilbath aircleaner to check choke operation....DU'oh! | | |
