| | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | What's the procedure for removing the center strip on an AD hood? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | turn hood over ,straighten out the bent over tabs on the underside of the hood and it will pop right off .
| | | | | Joined: Jun 2006 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 80 | Be carefull with those tabs. When I was removing mine some of them broke off. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Thanks for the help... sorry for the delay in responding, I've been out of town. | | | | | Joined: Jul 2008 Posts: 15 New Guy | | New Guy Joined: Jul 2008 Posts: 15 | will the hood come apart when the strip is removed or will it stay together?
slim rides low
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | the strip does not hold the hood together it is just a trim pc. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | This type of private negotiation should take place in a Private Message.
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Hey slimneverdies - the two hood halves are riveted together. You can see this inside the hood when you are straightening the tabs to remove the hood strip. The hood will not come apart by removing the center strip. | | | | | Joined: Jul 2008 Posts: 15 New Guy | | New Guy Joined: Jul 2008 Posts: 15 | I see said the blind man  .I finally removed it. I dont know why I thought it held the two halfs together. Thanks
slim rides low
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I cleaned out a few posts that were buying and selling. Please do that in the swap meet. Thanks,
