2 members (Otto Skorzeny, TexasFarmTruck), 83 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
#385712 03/09/2008 4:59 AM
Cleaning all the gunk and crud off the 261 engine to prepare to rebuild and looking closer at the oil pan I see what looks like two iron pipes with end caps and cut wires sticking out? Previous oil temp sensors??? Does a 261 pan have these? What do you think? Can post picture, but need help.
If removing patching these is there any advice on doing it, weld, etc?
Eric
Could it be some kind of oil pan heater, Post pictures someone will know for sure.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Self Destruct? eeeek
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Tried to paste pics of oil pan so all can see but not successful...is there a way to insert pics?
Eric
U
U Offline
Not on this site.
You have to post a link to the picture.
go to
www.picturetrail.com
free and very easy to load pictures to. then copy url and paste here in your message
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Ex Hall Monitor
Ex Hall Monitor
Do a search on linking pics in ITShort Bus or General Truck Talk. This is covered a lot. Bill is supposed to be working on re-doing the glovebox manual that explains to new members how to link pics but I don't think he has it done yet.
Finally got some pic's of the unknown pipes comming out of the oil pan (not a bomb).
Any ideal what used for and can they be removed welded up.
See pic's on link below:
http://good-times.webshots.com/album/563635858KHxPHD
Thnnks,
Eric
They could be an older style oil heater setup for winter climates.Just a thought.
Drew
Ex Hall Monitor
Ex Hall Monitor
I've not seen the like before. I'm in there with DrewP. As for removing & welding the hole shut, I don't see why you couldn't but remember it's only original once. ohwell
Why not just swap oil pans? There must be a bunch of 235 pans out there that will bolt right on. I agree with the others that you've probably got some sort of heater for cold weather warm-up, but once you start welding on your pan, it will probably warp and leak. Maybe once the heater is removed, simple pipe plugs could be used to fill the holes. The pan will have to be removed and cleaned, no matter what you decide to do.
1 Offline
drop the pan and take a look.
mabey some kind of oil cooler hookup
I vote that it is oil heating elements. "sort of" like what is in a water heater. Do you know the history on this truck? Maybe it came from some part of the country that gets real cold.
