1 members (TexasA&M48Truck), 190 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#38553 06/04/2003 8:52 PM
Hello great gurus,
I have a question. I have a 65 GMC pick up. Do any of you know if the front end from a 79 Monte Carlo would work in a swap? If not what type of vehicles would be best suited. Maybe I should swap out with an early 70's truck??? You folks please offer any help you can. Thanks.
Turn them Tires, so ya can
smoke 'em and choke 'em
[Linked Image from angelfire.com]
Vic... '65 GMC 910
#38554 06/04/2003 10:15 PM
Why would you want to change out the front end?
If you want to go to 5 bolt wheels change the spindles,(72 1/2t work I think) but there is no reason to change the entire front end.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
#38555 06/05/2003 12:30 AM
71 to 72 will bolt in with the a-arms and all cool
#38556 06/05/2003 2:34 AM
And there's an early-70s GMC rustbucket for sale over on the boards, cheap. It's mechanically sound. Good source for front end parts, 5 bolt wheels, disk brake conversion, etc, etc. Power steering too. And it's cheap. I know the guy who's selling it. ;-)
Great donor vehicle for a 60s Chevy upgrade.
George
53 3600
#38557 06/05/2003 3:47 AM
Junior Member
Junior Member
Hello there.. read a thread I started called "Cheap Donor Truck".. I am in the process of installing a 1985 gmc frame under my 1960 chev apache shortbox.. so far everything is going well.. I have the Brake booster and tilt steering column installed in the cab I used many parts from the 85 that were almost a direct bolt in. the '85 brake pedal Assy was an easy install. I do have to shorten the frame but so far everything look slike its gonna go well.. pls email me for more info.. I do have access to a digi camera,.. if you are interested in the brake/column work. [email protected]
thank you hopefully we can swap some tips
#38558 06/05/2003 3:50 AM
Junior Member
Junior Member
I am also going to use the '85 throttle pedal and parking brake assy. No more stupid under the column brake for me.
#38559 06/05/2003 4:21 AM
Hey Bosher,
I would love to have some pics of your progress. I plan on changing alot of things to make the truck more modern. I will probably be the next 3-5 years. But I need to make my plan now. That way I don't change things 50 times. Where in Canada are you? And please send me all the pics you can.
P.S. I know where there is a early 60's frame at here in NS.
Vic... '65 GMC 910
#38560 06/06/2003 3:45 AM
Junior Member
Junior Member
once I get a little further along I'll take some pictures..
#38561 06/10/2003 9:24 PM
Thanks. That would be appreciated.
Vic... '65 GMC 910
