5 members (59 fleet, Oswald, Peggy M, Bill Hanlon, Rnl364), 95 guests, and 3 robots.
Topics128,064
Posts1,055,859
Members48,428
#385033 03/08/2008 1:02 AM
I
I Offline
I have a few panels that have seemed to belly up throught time etc. Are these panels welded from underneath or are the screwed to the frame from the inside. I completely gutted the old work inside. I was wondering which is the best route to secure these down so they never pop up again. Thanx guys ! Cheerz !....p.s each panel is 35 inches wide.
All our school buses, '85 and newer, have the metal floor welded to the bus body which is secured to the chassis. I think you will find yours welded to. I have worked on school bus for the last 15 years here in Missouri, and 99% of them had 3/4 ply wood over the metal floor. The wood is an excellent insulator and sound deadener, but it all so rots easily. I have changed out floor panels from rust out, so the old one was easy to remove. I drilled holes at each bracket and joint, and plug welded the new metal in, its just to dirty to try and weld from the bottom side. Joe
Moderated by  ndkid275, Phak1
