1 members (CuzzFuzz), 101 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#383962 03/05/2008 10:38 PM
jdl
Offline
Are the horns that are mounted on the engine valuable or the one's mounted in the grill? Or are they supposed to be mounted on the grill at all?
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #383965 03/05/2008 10:49 PM
JDL, my 54's horn is mounted on the grill, as have been other 54's that I've seen. The earlier AD's were mounted on the manifold. As far as value, I know that I've seen them on Ebay for not to much money.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
jdl
Offline
Oh, cause I was down under my truck looking at the tranny, or trying to, to get it unstuck out of third, and lifted my head and found two horns mounted on the bottom of my grill. Koolkar told me that the ones on the manifold were more valuable.
Jordan D. Long
Photobucket
jdl #383976 03/05/2008 11:12 PM
What happened to the opossums in the seat?
~Jim
Jordan,
The 1954 single horn or dual horns were mounted on front side of the radiator mounting frame (not under the grill). Here are the mounting instructions.
Tim
jdl
Offline
The possums are gone. Now, tclederman, that link doesn't work. But, I get your point. I also now know that what you said is true, because I didn't really mean "under", but I saw that they were in between the bars.
Jordan D. Long
Photobucket
Jordan, what transmission does your truck have? Is it a 3-Speed with a column-mounted shifter? If so, you should find a couple of levers down at the end of the steering column that you should be able to access and manipulate just by raising the hood. If that unit is worn to where there is a little slop or play in the [censored] and you happen to let the clutch out without having the gearshift all the way into a gear it will hang up and you cannot move the gear shift.
jdl
Offline
3 speed on the column. I can't seem to get the levers to move, although I know that it does shift.
Jordan D. Long
Photobucket
tc,
that link does work just checked it.
dave
1954 custom 1-ton (1 of a kind)
Works for me.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
I thought you were talking about cattle horns on the hood
Works for me, too - oddly.
David Colter
jdl
Offline
Well, it comes up in another tab, with the address and everything, but the screen where words are supposed to be is white, and the bar at the bottom of my screen says "Done".
Jordan D. Long
Photobucket
Its a pdf file that gets downloaded into your computer and can then be read with Adobe Reader. Your web browser can be configured with the free Adobe Reader plug-in to read the file in the web browser.
http://www.adobe.com/products/acrobat/readstep2.html
Tim
