6 members (Otto Skorzeny, ShopRag, Gdads51, 55shaker, 78buckshot, Woogeroo), 147 guests, and 3 robots.
Topics128,268
Posts1,058,382
Members48,485
#384319 03/06/2008 5:45 PM
Hey guys, What is the best way to remove spray paint from my plastic dash insert without damaging the plastic/original color underneath? I spray painted the dash of my el camino 15 years ago, now I want to remove my teen age handy work. dang
Chris
1956 Chevrolet 4400
1959 Chevrolet Viking 60
1968 Chevrolet el Camino
2002 Chevrolet 1500HD 4x4
Ex Hall Monitor
Ex Hall Monitor
If it wasn't paint formulated to stick to plastic you might be able to warm it with a hair dryer and get it to loosen up. There are some "green" paint strippers that might be tame enough to strip the paint without harming the plastic. It should say on the label.
Chris,
Here is a trick that we use in the paint industry, as horrid as it sounds.
Easy Off (blue can) will remove paint without hazing or scaring plastic.
We use it on signs, plexiglass, etc with no problem. I can not say exactly what your dash is made of, but if you can find a hidden spot to test it out, it may be your solution. Just remember that it will remove paint from any metal as well.
That's a handy hint, Kidder... thanks for the tip. I don't need to know this right now, but you never know when you might need to! smile
~Trev
Thanks Kidder, I will give it a try. Where in so cal are you?
Chris
1956 Chevrolet 4400
Moderated by  ndkid275, Phak1
