| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Hey guys, What is the best way to remove spray paint from my plastic dash insert without damaging the plastic/original color underneath? I spray painted the dash of my el camino 15 years ago, now I want to remove my teen age handy work.
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it wasn't paint formulated to stick to plastic you might be able to warm it with a hair dryer and get it to loosen up. There are some "green" paint strippers that might be tame enough to strip the paint without harming the plastic. It should say on the label.
| | | | | Joined: Mar 2008 Posts: 2 New Guy | | New Guy Joined: Mar 2008 Posts: 2 | Chris,
Here is a trick that we use in the paint industry, as horrid as it sounds.
Easy Off (blue can) will remove paint without hazing or scaring plastic. We use it on signs, plexiglass, etc with no problem. I can not say exactly what your dash is made of, but if you can find a hidden spot to test it out, it may be your solution. Just remember that it will remove paint from any metal as well.
| | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | That's a handy hint, Kidder... thanks for the tip. I don't need to know this right now, but you never know when you might need to!  ~Trev | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Thanks Kidder, I will give it a try. Where in so cal are you?
Chris
