3 members (kbenz, JW51, Gib70), 168 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#383582 03/05/2008 2:45 AM
I have a 47 1.5 ton Chevy that I would like to make the rear springs a little lighter for a better ride. The old rig will probably never haul more than its own weight plus 1,000 lb's. When removing leaves from the spring stack, should you remove starting from the bottom every other one till I'm happy with the ride or one at a time till happy. Each spring starting with 12 leaves to mains and the other 10 get shorter till the bottom.
The springs have been taken apart cleaned and polished and ready to go back togeather just wondering what to do.
Former Workshop Owner
One thousand pounds isn't very much of a payload. If you carry a half dozen or so kids and a couple adults in a parade, you could surely exceed that.
I would start at the bottom. I don't think that there is a general rule. But don't forget that the springs also keep the rear axle from over twisting on acceleration.
I have never tried to soften a ride on a big truck, hopefully someone who has will enlighten us both.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Its own weight is probably 4500 pounds depending on whats there.
Im interested in what others will say to this. Hmmm...
My 1953 Chevrolet
1947.1 Gallery
I don't know, but by the time you got enough leaves removed to get a soft ride you probably could not carry anything, and stand a very good chance of breaking a spring. I would not do it.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
This old Chevy started out as schoolbus and has been converted into some what of a suburban. The only thing that remains of the bus is the frame and cowl forward. The frame was shortened 4' and a 9' pickup bed added behind the cowl for passenger area. It is used for a personal pleasure rig that rides to rough. After our first road tip of 600 miles through Arkansas to peditt jean swap meet we decided to soften the rear springs as they have no give at all with the current load. We plan on taking the old truck to Hutchenson Kansas in June for a truck show and would like a little smother ride as we plan to make the trip on rural mostly two lane roads. I'll post some pictures when I figure out how.
