10 members (Gray_Ghost, Shade Baby, 68ironhead, Gdads51, Pre '68 Dave, Otto Skorzeny, 1955 1 Series, joe apple, dt235sd, PAUL Berardi), 137 guests, and 1 robot.
Topics128,104
Posts1,056,197
Members48,436
#384002 03/06/2008 12:32 AM
Its such a coincidence that I have being loosing coolant but there was no sign of it coming from the heater now there is .It just started leaking today from the bottom inlet pipe I think.... That is my question number 1 is the inlet the hose coming from the water pump,or the top hose from the thermostat housing.. I know the core can be repaired..
Question 2 while I have the heater out of the truck can I put a plug in the inlet hose and outlet hose with out the hoses exploding so I can drive the truck and at the same time Shall I put a shut off valve on the inlet hose when i put it back on. Does anybody have a drawing of my heater my manual doesn't show it...thanks again .Peter
Hey Peter,
Just loop one of the hoses to the other port on the pump making a circle. Won't hurt it at all. Then get your heater core rebuilt, you might want to rebuild the control valve while everything is out.
Bruce
My Trucks
Stuff I Collect
I don't think i have a control valve its a recirculating heater. So you say take the bottom hose to where the the top hose comes from (the thermostat housing) and attach the bottom hose to that housing...Good Idea
The hose connections on the water pump are intake connections. The water pump forces water into the block and the water flow exits from the head at the thermostat housing.
Only Canadians in BC can drive around in winter without the heater!
1951 1 Ton Completed
Fred Its summer here in BC now Has it stopped Snowing back east yet???? Peter....
So what you say above is what I wanted to know The inlet is the top fitting on the heater and the bottom fitting is the outlet.
What about my idea about a valve when I don't need the heater will that work if I turn the coolant off to the heater??? Thanks Peter
Heater problems like that have been covered before and could be found under "search".
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I tried but couldn't find a thing probably not using the right lanquage...
Pete,
I put one of those valves on mine but I haven't driven it in summer yet. It will stop the flow through the heater and cut down on the amount of heat it produces. Some say blocking the flow completely is a bad thing for the core. It really doesn't matter which side the valve goes on as it still stops the flow.
Back east here, it was a day of shoveling yesterday! Driving my truck is still yet just a dream this year!
Any other comments on Blocking the flow of coolant to the heater core during the summer...my reason for doing it was to keep my truck cooler in the cab... would it be a better Idea to open the valve once in a while and to let the water flow..and then shut it off again...Peter
If you need to get the core repaired I recommend Maurice's Radiator Shop in town. They are probably the best and the only ones who could/would repair my circular core.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
