0 members (),
127
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Its such a coincidence that I have being loosing coolant but there was no sign of it coming from the heater now there is .It just started leaking today from the bottom inlet pipe I think.... That is my question number 1 is the inlet the hose coming from the water pump,or the top hose from the thermostat housing.. I know the core can be repaired.. Question 2 while I have the heater out of the truck can I put a plug in the inlet hose and outlet hose with out the hoses exploding so I can drive the truck and at the same time Shall I put a shut off valve on the inlet hose when i put it back on. Does anybody have a drawing of my heater my manual doesn't show it...thanks again .Peter | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey Peter, Just loop one of the hoses to the other port on the pump making a circle. Won't hurt it at all. Then get your heater core rebuilt, you might want to rebuild the control valve while everything is out.
Bruce | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I don't think i have a control valve its a recirculating heater. So you say take the bottom hose to where the the top hose comes from (the thermostat housing) and attach the bottom hose to that housing...Good Idea | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The hose connections on the water pump are intake connections. The water pump forces water into the block and the water flow exits from the head at the thermostat housing.
Only Canadians in BC can drive around in winter without the heater! | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Fred Its summer here in BC now Has it stopped Snowing back east yet???? Peter....
So what you say above is what I wanted to know The inlet is the top fitting on the heater and the bottom fitting is the outlet.
What about my idea about a valve when I don't need the heater will that work if I turn the coolant off to the heater??? Thanks Peter | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Heater problems like that have been covered before and could be found under "search". | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I tried but couldn't find a thing probably not using the right lanquage... | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Pete, I put one of those valves on mine but I haven't driven it in summer yet. It will stop the flow through the heater and cut down on the amount of heat it produces. Some say blocking the flow completely is a bad thing for the core. It really doesn't matter which side the valve goes on as it still stops the flow.
Back east here, it was a day of shoveling yesterday! Driving my truck is still yet just a dream this year! | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Any other comments on Blocking the flow of coolant to the heater core during the summer...my reason for doing it was to keep my truck cooler in the cab... would it be a better Idea to open the valve once in a while and to let the water flow..and then shut it off again...Peter | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | If you need to get the core repaired I recommend Maurice's Radiator Shop in town. They are probably the best and the only ones who could/would repair my circular core. | | |
