| | | Forums66 Topics128,125 Posts1,056,337 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Are the horns that are mounted on the engine valuable or the one's mounted in the grill? Or are they supposed to be mounted on the grill at all? | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | JDL, my 54's horn is mounted on the grill, as have been other 54's that I've seen. The earlier AD's were mounted on the manifold. As far as value, I know that I've seen them on Ebay for not to much money. Samantha | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Oh, cause I was down under my truck looking at the tranny, or trying to, to get it unstuck out of third, and lifted my head and found two horns mounted on the bottom of my grill. Koolkar told me that the ones on the manifold were more valuable. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What happened to the opossums in the seat?
~Jim
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jordan, The 1954 single horn or dual horns were mounted on front side of the radiator mounting frame (not under the grill). Here are the mounting instructions. Tim | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | The possums are gone. Now, tclederman, that link doesn't work. But, I get your point. I also now know that what you said is true, because I didn't really mean "under", but I saw that they were in between the bars. | | | | | Joined: Sep 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 75 | Jordan, what transmission does your truck have? Is it a 3-Speed with a column-mounted shifter? If so, you should find a couple of levers down at the end of the steering column that you should be able to access and manipulate just by raising the hood. If that unit is worn to where there is a little slop or play in the [censored] and you happen to let the clutch out without having the gearshift all the way into a gear it will hang up and you cannot move the gear shift. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | 3 speed on the column. I can't seem to get the levers to move, although I know that it does shift. | | | | | Joined: Dec 2004 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 58 | tc, that link does work just checked it. dave
1954 custom 1-ton (1 of a kind) | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I thought you were talking about cattle horns on the hood | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Works for me, too - oddly. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well, it comes up in another tab, with the address and everything, but the screen where words are supposed to be is white, and the bar at the bottom of my screen says "Done". | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Its a pdf file that gets downloaded into your computer and can then be read with Adobe Reader. Your web browser can be configured with the free Adobe Reader plug-in to read the file in the web browser. http://www.adobe.com/products/acrobat/readstep2.htmlTim | | |
