3 members (Gray_Ghost, Otto Skorzeny, Joe H), 88 guests, and 4 robots.
Topics128,065
Posts1,055,865
Members48,428
#383186 03/04/2008 4:01 AM
I am building a 48 chevy pu and I was wondering if anyone has made a tilt front end for an ad truck. Thanks.
cackle #383320 03/04/2008 2:51 PM
What is a tilt front end?
~Jim
That's where someone welds the fenders to the hood, puts a hinge in front of the radiator area and cuts the sheet metal at the firewall area to allow the whole assembly tilt forward. When done right, looks good. When done wrong, looks unsaveable!
MNSmith #383417 03/04/2008 7:31 PM
Houston54
Unregistered
Houston54
Unregistered
Here is a site showing how one guy did this to his GMC. Lots of other great/useful information on there also.
http://purplesagetradingpost.com/sumner/sumnerindex.html
cackle #383528 03/05/2008 12:35 AM
Thanks for the info, Iam looking for ideas on the type that pulls out then up.
cackle #383676 03/05/2008 4:31 AM
If you're talking about just tilting the hood forward, it was Buick in the late 80's, early 90's that did that. They had the whole mechanism and latch together that looked like it would easily adapt to about anything,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
There used to be a kit available to front tilt the hood on an AD truck.
I've seen one done, and while it looked nice the owner wasn't very happy with it. His problem was that unless you were real careful it was easy to make the hood go the wrong way and damage the paint.
OldSub #383720 03/05/2008 5:41 AM
Houston54
Unregistered
Houston54
Unregistered
No Limit Engineering sells the tilt hood kit for ADs. I have one I decided not to use. It seemed to me that access to the front of the engine and radiator are compromised with that kit.
#384048 03/06/2008 1:58 AM
I was thinking of tilting the entire front end including the fenders, I had taken pictures off one truck, but when I took my computer for service the "tech" erased all my memory, I should have backed up.
