| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 15 New Guy | | New Guy Joined: Aug 2007 Posts: 15 | I am building a 48 chevy pu and I was wondering if anyone has made a tilt front end for an ad truck. Thanks. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What is a tilt front end?
~Jim
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | That's where someone welds the fenders to the hood, puts a hinge in front of the radiator area and cuts the sheet metal at the firewall area to allow the whole assembly tilt forward. When done right, looks good. When done wrong, looks unsaveable! | | | | | Joined: Aug 2007 Posts: 15 New Guy | | New Guy Joined: Aug 2007 Posts: 15 | Thanks for the info, Iam looking for ideas on the type that pulls out then up. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you're talking about just tilting the hood forward, it was Buick in the late 80's, early 90's that did that. They had the whole mechanism and latch together that looked like it would easily adapt to about anything, Scott | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There used to be a kit available to front tilt the hood on an AD truck.
I've seen one done, and while it looked nice the owner wasn't very happy with it. His problem was that unless you were real careful it was easy to make the hood go the wrong way and damage the paint.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | | Houston54 Unregistered | | Houston54 Unregistered | No Limit Engineering sells the tilt hood kit for ADs. I have one I decided not to use. It seemed to me that access to the front of the engine and radiator are compromised with that kit. | | | | | Joined: Aug 2007 Posts: 15 New Guy | | New Guy Joined: Aug 2007 Posts: 15 | I was thinking of tilting the entire front end including the fenders, I had taken pictures off one truck, but when I took my computer for service the "tech" erased all my memory, I should have backed up. | | |
