| | | Forums66 Topics128,272 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I had a vinyl pad made for under the hood, about 3 by 4 foot. All attempts to glue it in place have been temporary. The heat seems to softer the glue and it starts separating from the hood. any advice? | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Magnets. I didn't want to was the straps on the hood part of the front end bra I bought, so I sewed magnets into. I think there like 40lb pull and are 1in sq. by 1/8in thick. Here's the bad news, I can't remember where I ordered them. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | All of the under hood pads I've seen used the push in type of fastener. I assume because of the problem you're facing of the engine heat softening glue.
| | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I don't think there is a glue tuff enough to handle the high temps under the hood. The push in fasteners Tiny talks about can be found at Tractor Supply for under a buck a piece. The magnet approach is a good idea also, the advantage being you can put a magnet wherever there isn't a brace without doing any drilling. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well, the push in fasteners would necessitate drilling a hole thru the hood, do that isn't a consideration. the magnets either would have to be sewn on or glued on. Looks like it will have to be the resew job or I might try 3M #90, it comes in a caulk tube. Someone else mentioned it. Thanks anyway, As soon as it gets warm enough to try the new adhesive I will. | | | | | Joined: Mar 2008 Posts: 32 Apprentice | | Apprentice Joined: Mar 2008 Posts: 32 | I used beads of 3m caulking on pad and then sprayed fast drying glue to hold it in place while caulking dried, its never moved since .  | | |
