| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 42 New Guy | | New Guy Joined: Feb 2011 Posts: 42 | I recently bought a 1961 chevy k 10 short fleetside pick up. The VIN and the frame match up. However, I can't seem to identify the motor. It is a V8 with high performance heads (the ones with the double humps on the ends...), headers, old rotten glass packs, and a 600 cfm holley 4 barrel carb. The old owner said that the motor was a 350, but a friend of mine told me the harmonic balancer was too small for a 350. He said it was more likely that the motor was a 327 or a 283. The 283 was the only V8 offered in 61, so i'm hoping that its the motor in my truck. I need to know how to id the motor so i can rebuild it. Any hints or tips as to how i can do this would be greatly appreciated.
Matt | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Go to www.mortec.com Hey,, Welcome to the Stovebolt
| | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | You should be able to find some numbers on the block. There are two usual spots, a casting number of the back of the engine drivers side. Then a set of numbers on the passenger front of the block. They are on the flat ledge of the block just infront of the head. You might have to move the generator to see them(depend's) Then use the Mortec hyperlink to identify. | | | | | Joined: Feb 2011 Posts: 42 New Guy | | New Guy Joined: Feb 2011 Posts: 42 | Thanks for the help. I haven't found anything yet, but the truck is still in one piece. (a frame off restoration will start soon, so i'll be able to get a real good look at the motor. Any other tips anybody else might have is welcome.
Thanks, Matt | | |
