Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Sedgewick, Charles in CA, crenwelge, UtahYork, TexasFarmTruck, Mike1933), 161 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#38205 03/26/2003 8:49 PM
Because of my inexperience,I'm a woodworker, I detroyed my clutch on my '51 GMC 1/2 ton. It had was frozen to the flywheel and it blew apart in the process of unsticking it.
Anyway here is my question the pressure plate has a few small gouges . It is a new pressure plate with less than 50 mileson it. Can I sand out the rough spots and reuse it?
Also does anyone know if the pilot bearing is the same for a GMC as it is for a Chevy?
#38206 03/26/2003 10:38 PM
If you sand out the spots, you will have uneven wear on the surface and the clutch will be chattery. Either get it machined or install it as-is and let the new clutch wear it down evenly.
Paint & Body Shop moderator
#38207 04/12/2003 5:03 PM
Have both pressure plate and flywheel machined
dan G
