0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | In looking at older posts it looks like I can run my '60 235 with no oil filtering. That is, I can plug the holes at the block. I am changing out the intake manifold so don't have a place to mount it. I'm also thinking of treating her to a beehive one from Speedway. Anyway, just want to be sure if I can plug the oil lines at the block for a while until I get it sorted out.
40 Chevy 1/2 ton
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | You should be able to fit plugs in the holes the oil lines come out of. I am thinking of removing the oil filter entirely on my 1956 235". I change the oil frequently and understand that these by-pass filters don't filter as much as you would like. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, you can plug the oil line holes in the 1960 235 block with no problems. Just change the oil regularly. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | This may sound stupid, but make sure you do not have a 261 with the full flow oil filter. These cannot be plugged. The oil line must be looped back to the block. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks everyone. That is what I thought but wasn't 100%. I'd rather be a pest and ask instead of frying an engine!
40 Chevy 1/2 ton
| | | | | Joined: Jun 2006 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 91 | My 1960 235 didn't ever have a oil filter, but I plan to add one because I happen to have one.
I will still need to change oil just as frequent. | | |
