1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#377138 02/19/2008 2:58 AM
I have a 58 60 viking truck with a In line 6cy engine. Im am trying to I.D. 235 or 261 - need to know what to look for. The truck has 8.25-20 tires now, was this the original size? It has a GM vaccum operated 2 speed rear end, I would like to find out the gear ratio. I would also like to I.D. the trans. It is a manual 4 speed with a Tulsa pto mounted on it. If this helps the VIN tag on the inside of the drivers door says 6C58Sl24689 19,000lb GVW paint 708 wheelbase 174.
You've got a Jobmaster 6000..The 'C' designator didn't come out until the 60's..Original engine is a 261..there should be a number stamped next to the distributor that will tell you the engine size..to identify the 2spd rear end, there should be a tag on it with numbers..
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Stick #377632 02/20/2008 3:58 AM
Welcome Farmboy,
I have lost of info on my web page...see link below.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
They made a C-60 Viking. I have one also. That's what the chrome on the side of the hood says. Maybe you need mine also. Call me if you need photos or anything. dlhenk. 785-738-8714
dlhenk #380163 02/26/2008 4:11 AM
dlhenk,
Your 1958 fender emblem should say "Chevrolet Viking 60", not C60. They didn't use the "C" in front of the number until sometime in the 1960's (I think 1963). Viking and "C" were not used at the same time, they dropped Viking when they went to "C".
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #381666 02/29/2008 3:51 PM
thats correct mike, my 59 is the same way.
Chris
1956 Chevrolet 4400
1959 Chevrolet Viking 60
1968 Chevrolet el Camino
2002 Chevrolet 1500HD 4x4
