1 members (Southerntruck),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 10 New Guy | | New Guy Joined: Feb 2008 Posts: 10 | I have a 58 60 viking truck with a In line 6cy engine. Im am trying to I.D. 235 or 261 - need to know what to look for. The truck has 8.25-20 tires now, was this the original size? It has a GM vaccum operated 2 speed rear end, I would like to find out the gear ratio. I would also like to I.D. the trans. It is a manual 4 speed with a Tulsa pto mounted on it. If this helps the VIN tag on the inside of the drivers door says 6C58Sl24689 19,000lb GVW paint 708 wheelbase 174.
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | You've got a Jobmaster 6000..The 'C' designator didn't come out until the 60's..Original engine is a 261..there should be a number stamped next to the distributor that will tell you the engine size..to identify the 2spd rear end, there should be a tag on it with numbers..
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome Farmboy, I have lost of info on my web page...see link below. Mike B  | | | | | Joined: Jan 2006 Posts: 19 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 19 | They made a C-60 Viking. I have one also. That's what the chrome on the side of the hood says. Maybe you need mine also. Call me if you need photos or anything. dlhenk. 785-738-8714 | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | dlhenk, Your 1958 fender emblem should say "Chevrolet Viking 60", not C60. They didn't use the "C" in front of the number until sometime in the 1960's (I think 1963). Viking and "C" were not used at the same time, they dropped Viking when they went to "C". Mike B  | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | thats correct mike, my 59 is the same way.
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
