| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37998 03/02/2005 5:09 AM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | I took my truck on a 20 mile drive the other day down to the body shop. After i got off the freeway and pulled in i backed up and the chatter was so bad i almost got whiplash. I pulled forward and it did it as well, but is way worse in reverse. I dont notice it much when i just drive it on short drives. Do you think a long drive could cause this? Clutch not adjusted properly and is slipping on the freeway? I would think if it was slipping for 20 miles it would be so burnt or glazed that it wouldnt work at all. Any insight on this? thanks | | |
#37999 03/02/2005 6:44 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | You might have some oil leakage getting on the clutch. Look for dripping.
if it dosen't need fixed, break it
#38000 03/03/2005 4:16 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Check the motor mounts as well. | | |
#38001 03/03/2005 4:30 AM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | if my truck leaks oil i cant tell there is never even a drop on the ground. how would the motor mounts cause this? Does it sound like a flywheel that might be heat checked or something? Anyone with much experience doing a clutch and flywheel on this style truck and might have some insight on pointers or anything? | | |
#38002 03/03/2005 6:27 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Det.64 what kinda truck im assumin 64chev/gmc. if so should be a 3/4 cast iron bellhouse with either a 3speed or 4speed granny low tranny.flywheel could be heat checked/have some oil on clutch disc etc.drop inspection cover down off bottom of the bellhouse and have a look with a lite!  | | |
