4 members (Shaffer's1950, artinva, Chip O, 1 invisible), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#37998 03/02/2005 5:09 AM
Junior Member
Junior Member
I took my truck on a 20 mile drive the other day down to the body shop. After i got off the freeway and pulled in i backed up and the chatter was so bad i almost got whiplash. I pulled forward and it did it as well, but is way worse in reverse. I dont notice it much when i just drive it on short drives. Do you think a long drive could cause this? Clutch not adjusted properly and is slipping on the freeway? I would think if it was slipping for 20 miles it would be so burnt or glazed that it wouldnt work at all. Any insight on this? thanks
#37999 03/02/2005 6:44 PM
You might have some oil leakage getting on the clutch. Look for dripping.
if it dosen't need fixed, break it
#38000 03/03/2005 4:16 AM
Check the motor mounts as well.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#38001 03/03/2005 4:30 AM
Junior Member
Junior Member
if my truck leaks oil i cant tell there is never even a drop on the ground. how would the motor mounts cause this? Does it sound like a flywheel that might be heat checked or something? Anyone with much experience doing a clutch and flywheel on this style truck and might have some insight on pointers or anything?
#38002 03/03/2005 6:27 PM
Det.64 what kinda truck im assumin 64chev/gmc. if so should be a 3/4 cast iron bellhouse with either a 3speed or 4speed granny low tranny.flywheel could be heat checked/have some oil on clutch disc etc.drop inspection cover down off bottom of the bellhouse and have a look with a lite! wink
