0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#379397 02/24/2008 1:58 PM
i mounted my frl uhit to a service cart, had a 10ft. hose made up for oiler hose going to tools, put quick couplers put on evrything. put all air tools on bottom shelf of cart, now i just push cart to where i need it and go to work. is 10ft hose short enough to carry oil to my tools.
1955 CHEVY 3600 TF
wadd55 #379424 02/24/2008 3:12 PM
Ex Hall Monitor
Ex Hall Monitor
frl?????
Tiny #379438 02/24/2008 3:50 PM
Me too?
gazim #379445 02/24/2008 4:05 PM
Filter, Regulator, Lubricator unit
Flxible #379481 02/24/2008 5:24 PM
wadd55,
I think the atomized oil will make it 10', although it's recommended that a oiler be placed directly in front of the device to be lubricated.
I have other thoughts on this setup....a oiler in a air line in a home shop or hobby environment is bad news. At some point in time something will get attached to that line that you certainly don't want oil in. It might be a spray gun or it could be a DA sander that spews oil all over your freshly sanded hood.
Air tools don't require lots of lube. I always stick a couple of drops of oil into the quick connect each time I use a tool. This way I can determine when the tool get oiled and avoid any surprises...as they say, my two cents.
Stuart
atomarc #379497 02/24/2008 5:54 PM
I can testify Stuart has it exactly right, automatic oiling of anything to do with bodywork is a mistake
Flxible #379532 02/24/2008 7:16 PM
Leave the filter and regulator on your cart if it works for you, just sh**-can the lubricator.
'67 GMC 3/4 292 4spd
Richard #379545 02/24/2008 7:35 PM
You can leave the lubricator....just don't fill it! smile
Stuart
atomarc #379691 02/25/2008 2:41 AM
that is how i was doing it, just dropping a few drops of oil at quick coupling and go to work, but i heard from some people you need lubricator for air tools so i rigged this up. i think i will it hooked up but not put in any oil in it. after i did a lot of work on the cart and i do need filter and regulator but don`t want to mess up anything with oil
1955 CHEVY 3600 TF
wadd55 #380229 02/26/2008 5:58 AM
When I was wrenching full time as a John Deere service tech, I put a lube mister in series with the main air hose I used all the time. I did no body work and needed maximum power output from my air tools. This worked great but the air hose developed an oily coating on the outside. I had to replace the anvil on my CP749 impact wrench after a couple years of HARD use and I was amazed to find the lack of wear in the air motor area--no scratches or galling anywhere and the vanes looked brand new.
I would run the oil mister and just use a different hose when painting.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
Racecarl #380288 02/26/2008 3:05 PM
I have a mister in line to a RED 20' line and a clean line run in Blue 20' ....I have a sighn over the airlines ...red is Oily blue is clean ...took me a bit to teach the boys that ...but it works for us
1952 Chevy Shortbed
Photos in Photobucket
Moderated by  MNSmith
