4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 33 New Guy | | New Guy Joined: Jan 2008 Posts: 33 | i mounted my frl uhit to a service cart, had a 10ft. hose made up for oiler hose going to tools, put quick couplers put on evrything. put all air tools on bottom shelf of cart, now i just push cart to where i need it and go to work. is 10ft hose short enough to carry oil to my tools.
1955 CHEVY 3600 TF
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Filter, Regulator, Lubricator unit
Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | wadd55,
I think the atomized oil will make it 10', although it's recommended that a oiler be placed directly in front of the device to be lubricated.
I have other thoughts on this setup....a oiler in a air line in a home shop or hobby environment is bad news. At some point in time something will get attached to that line that you certainly don't want oil in. It might be a spray gun or it could be a DA sander that spews oil all over your freshly sanded hood.
Air tools don't require lots of lube. I always stick a couple of drops of oil into the quick connect each time I use a tool. This way I can determine when the tool get oiled and avoid any surprises...as they say, my two cents.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I can testify Stuart has it exactly right, automatic oiling of anything to do with bodywork is a mistake
Bill | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Leave the filter and regulator on your cart if it works for you, just sh**-can the lubricator.
'67 GMC 3/4 292 4spd
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | You can leave the lubricator....just don't fill it!  Stuart | | | | | Joined: Jan 2008 Posts: 33 New Guy | | New Guy Joined: Jan 2008 Posts: 33 | that is how i was doing it, just dropping a few drops of oil at quick coupling and go to work, but i heard from some people you need lubricator for air tools so i rigged this up. i think i will it hooked up but not put in any oil in it. after i did a lot of work on the cart and i do need filter and regulator but don`t want to mess up anything with oil
1955 CHEVY 3600 TF
| | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | When I was wrenching full time as a John Deere service tech, I put a lube mister in series with the main air hose I used all the time. I did no body work and needed maximum power output from my air tools. This worked great but the air hose developed an oily coating on the outside. I had to replace the anvil on my CP749 impact wrench after a couple years of HARD use and I was amazed to find the lack of wear in the air motor area--no scratches or galling anywhere and the vanes looked brand new.
I would run the oil mister and just use a different hose when painting. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I have a mister in line to a RED 20' line and a clean line run in Blue 20' ....I have a sighn over the airlines ...red is Oily blue is clean ...took me a bit to teach the boys that ...but it works for us | | |
