1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 21 Apprentice | | Apprentice Joined: Apr 2006 Posts: 21 | If anyone is looking to add A/C to their truck, I highly recommend Old Air. I wanted to add dehumidifed defrost, but it was not an option for my kit. I called them and explained what I wanted and ordered the switch I would need. The made me brackets and added the hardware I would need as well as sending me pictures on how to mount it. I was only charged for the switch. They are the best after market supplier I have dealt with to date. Just thought someone might want to know. Macziggy04 http://good-times.webshots.com/album/560933974hNcFzO?vhost=good-times
MACZ
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Good to know.
I can't recommend HotRod Air. My system has never worked right. Their techs can't figure out why. Wish you had posted this last June.
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Good to know I have been looking at Old Air because I like the fact that they have a control panel for the Task Force trucks that look just like the stock deluxe piece. | | | | | | Houston54 Unregistered | | Houston54 Unregistered | This sounds close to vendor banging there Cletis. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I realized that as I was writing it. I trimmed it to just the facts as I see them before submitting. I've changed the wording a little more now. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I went with Old Aire in my 54 truck because all the major line hookups are on the engine side of the firewall. Have used the V. Aire and discovered working up under the dash is for younger more flexible guys. Olde Aire's underdash distribution system is great and their 3 speed fan will flip your skirt on HIGH and will be a whisper on the LOW setting. Didn't need their tech support as everything went in according to the instructions. I'd rate it 4 out of 5 stars.
Dave | | | | | | Houston54 Unregistered | | Houston54 Unregistered | This is very timely information for me. All of the manufacturers make it sound like theirs is the best so getting first hand accounts is priceless to me. I appreciate the input. | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | How about one of you that has used old aire shooting me an address or e-mail, i would like to talk to them Thanks, Mike Bourg | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | http://www.oldairproducts.com/ Old Air Products 8744 Forum Way Ft. Worth, Texas 76140 Phone: 817-531-2665 Fax: 817-531-3257
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | Thanks I needed that Mike Bopurg | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | Has anyone used their Hurricane system? That's what I was planning to purchase later this year. It appears to be about the same size as the stock heater box on a 46 model. The Task Force should have a lot more room under the dash and a lot more options.
Thanks 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I used their Hurricane system in my 54 truck. Had all the mounting brackets for the low compressor mount with alternator above. The underdash evaporator used a couple existing holes from the old heater (which is replaced with the new enclosed heater) as pilots for attachment. Unlike some others, the Olde Aire unit can be opened up should you need to get inside the case and I mentioned that the 3 speed fan is powerful but has a really quiet low speed which makes for a quiet cab.
The only negative is the visual effect of having the main line attachment points visible on the firewall. All hoses were crimped and no cuts were needed to the core support to run the hard lines that attach to the condensor.
I would purchase another hurricane system from them if the need arose.
Dave | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Fla54Chevy3100, Are you experiencing excessive belt wear and short belt life on your compressor drive with the low mount and alternator above? I was told by one individual that the belts wear very fast. Cleon | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I set my 235 up a little differently than most. I fabricated an alternator mount that goes on the passengers side of the block and left the space above my low mount compressor for my future power steering pump. By doing it this way, and using a 2 groove harmonic balancer, I run only one belt from the alternator over the water pump pulley down to the inboard groove. I run the compressor off the front groove of the balancer.
I've noted with a couple other project trucks that pulley alignment is critical, especially when you're trying to run 2 off of one belt. I found that using the "Gatorback" belts minimized the wear and tear. They seem to be a whole lot less likely to stretch and run quieter. If you're running a big alternator you might find they would be worth the extra money.
Dave | | | | | Joined: Mar 2008 Posts: 1 New Guy | | New Guy Joined: Mar 2008 Posts: 1 | Boy am I glad to find ya'll. I've got a '54 1/2 ton which, being in Houston, you need an A/C. Seems the concensus is Old Aire. My concerns are: 1) Is the 235 going to overheat 2)can I get a larger radiator- such as the Desert Cooler- or is there too little space and 3) can I keep my original generator or am I doomed to switch over to an alternator.
As you may can tell, I'd like to keep things as original as possible just without passing out while driving in August.
Any of your experience is greatly appreciated! | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | After installation it will be nessary to change your radiator cap to about a 16lb. This will keep your engine cooler. We went through this in the add on days many years ago. I have a 16lb cap and a 16in pusher fan installed and have no trouble with over heating with the Old Air system. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | As mentioned before, I'm running the Old Aire Hurricane system in my 54 truck with a 7 pound cap and have experienced NO overheating problems or belching of coolant into my overflow tank. I'm running a new radiator from LMC (no special order), a 25-75 coolant mix with distilled water, 6 blade fan on an "early" 216-235 adaptor plate mounted pump, and I did add a 16" manually controlled pusher fan in front.
Only time I've had to kick on the fan was when I was the 9th vehicle in line at a fast food gas palace at shift-change time.
I'm not saying that you should NOT go with a system pressure increase but that with a decent fan/waterpump setup that it has been a non-issue with my truck. Keeping the engine temperature stabilized at thermostat temperature and avoiding pits and peaks will insure that you've minimized cylinder wall wear.
For those of you who are considering adding A/C to your truck, OldeAire offers a quality product and getting your cooling system properly set up will make "overheating" a none issue.
Dave | | | | | Joined: Mar 2007 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 47 | I bought one of their units for my '50. I got it professionally installed and it worked for about 2 hours and died. Never worked again and I got no support form oldair.
Cost me over a grand to learn a hard lesson. | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | I have dealt with Old Air Porducts for some years now and have never (not saying it don't or won't happen)had any problem getting answers on thier products, They know the stuff they sell. Mike | | |
