13 members (greenie-reddy, Gdads51, 1955 1 Series, KEVINSKI, Greg_H, Bill Hanlon, Otto Skorzeny, klhansen, Ponchogl, cmayna, Peggy M, 2 invisible), 105 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#378567 02/22/2008 5:18 AM
well i have been hard at work on the frame of my 53chev 3100. i have made a frame jig and cut boxing plates for the front half and tacked them in.my need is should i box the back half of the frame? it is not going to be a show truck it will have mild power 400 horse or there about.i am going to build a cross member to mount the shocks from and build a k member from that to the cross member under the cab. what would you guys do?
gotta love old trucks
53chev #378672 02/22/2008 3:08 PM
I don't see a need to box the back half. I'm running close to 400hp in my 37 and its lighter than the AD chassis. No problems and believe me I do "air it out" sometimes. I did weld the cross piece for mounting the shocks which also gives it a "little" more strength....I say move ahead!
Houston54
Unregistered
Houston54
Unregistered
Why did you box the front? In my opinion you do it all or nothing. Boxing just the front may now transfer the torque forces into a more focused area which could accelerate metal fatigue. I boxed my 54 frame all the way back to the rear spring hangers.
#378692 02/22/2008 3:49 PM
i have a small boxed area in the engine compartment because of the 292 motor mounts. the middle section the factory did. the rear has a heavy duty tow bar made of 2'' receiver hitch stock http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=12A.jpg that also crosses the frame.
I'm done
Jim & Caroline
I didn't box mine at all. But then again, I'm just running a 350. If anyone has actually experienced any twisting of their frame from Torque, let me know. I wonder about that.
Would boxing the frame be stiffer than a lighter weight option, such as "X-ing" the frame with tubing?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
houston54 i boxed the front with plans on boxing the rear. but i cut my last peice of plate steel up for the rear peices but i f@#$%& up and they didnot fit. i was thinking with just boxing the arches and making a shock cross member and a k member to the midle cross member would be fine but your commit about metal fatigue got me thinkn.but achipmunk said that he has had no problems omn his 37. also has me thinking wich is what i wanted you guys to do so i make the right choice. thank you all
53chev #378995 02/23/2008 5:43 AM
Heck do it all unless you're in a big hurry. I always say, it's better to over do it than to have to do it over.
~Jim
