2 members (Materman, 55shaker),
68
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | well i have been hard at work on the frame of my 53chev 3100. i have made a frame jig and cut boxing plates for the front half and tacked them in.my need is should i box the back half of the frame? it is not going to be a show truck it will have mild power 400 horse or there about.i am going to build a cross member to mount the shocks from and build a k member from that to the cross member under the cab. what would you guys do?
gotta love old trucks
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I don't see a need to box the back half. I'm running close to 400hp in my 37 and its lighter than the AD chassis. No problems and believe me I do "air it out" sometimes. I did weld the cross piece for mounting the shocks which also gives it a "little" more strength....I say move ahead! | | | | | | Houston54 Unregistered | | Houston54 Unregistered | Why did you box the front? In my opinion you do it all or nothing. Boxing just the front may now transfer the torque forces into a more focused area which could accelerate metal fatigue. I boxed my 54 frame all the way back to the rear spring hangers. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i have a small boxed area in the engine compartment because of the 292 motor mounts. the middle section the factory did. the rear has a heavy duty tow bar made of 2'' receiver hitch stock http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=12A.jpg that also crosses the frame. I'm done
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I didn't box mine at all. But then again, I'm just running a 350. If anyone has actually experienced any twisting of their frame from Torque, let me know. I wonder about that. Would boxing the frame be stiffer than a lighter weight option, such as "X-ing" the frame with tubing?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | houston54 i boxed the front with plans on boxing the rear. but i cut my last peice of plate steel up for the rear peices but i f@#$%& up and they didnot fit. i was thinking with just boxing the arches and making a shock cross member and a k member to the midle cross member would be fine but your commit about metal fatigue got me thinkn.but achipmunk said that he has had no problems omn his 37. also has me thinking wich is what i wanted you guys to do so i make the right choice. thank you all
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Heck do it all unless you're in a big hurry. I always say, it's better to over do it than to have to do it over.
~Jim
