0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#377531 02/20/2008 1:12 AM
hi all just wondering how powdercoating holds up to heat like, on calipers and such? thanks
1951 chevy 4400
It goes thru a bake process so should do better than paint. I know on playground equipment it will fade with age (5/7 years in direct sunlight) but what won't. However I'm sure someone here has had experience in this and will drop by soon with a real answer.
~Jim
I am not experienced in this, but if you have to put the part in a 300 degree oven to liquify the powder, you might not want to put it on a part that may reach 300 degrees, right?
jomichael #377968 02/20/2008 11:12 PM
supposed to work fine on exhaust manifolds
Flxible #377972 02/20/2008 11:24 PM
Calipers would have to be completely disassembled proir to coating, the rubber components can't take the curing process.
Bill Burmeister
LONGBOX55 #378532 02/22/2008 4:05 AM
I used a lot of powder coating on my '51 and '53. My powder coater did not recommend using on parts that get over 300 degrees. Cecil.........
51Jimmy #378535 02/22/2008 4:08 AM
They have powder coatings that are specificlly made for high temps, like what your exhaust manifolds would see.
They also have flexible coatings and can now do leaf springs and such, which I always thought was a bad idea.
My 1953 Chevrolet
1947.1 Gallery
I am not sure they have any powdercoat good for exhaust manifolds?
I know they have a few different temperatures of powdercoat, but not that hot.
For exhaust manifolds the temp cold be around 1,000 degrees. I had mine ceramic coated, looks great, and is supposed to last a long time.
No sure ceramic coating brake calipers would be a good idea, as when they get hot you want them to radiate heat to cool off, the coating would hold the heat in, and possibly cook the seals if hot enough?
For the real answers call a powdercoater, and or a ceramic coater.
This is the place I like for ceramic coating: http://www.performancecoatings.com/performancecoatings.html
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #378605 02/22/2008 7:16 AM
Powder coating for hi-temps.
It says 1000 degrees F and up to 1200 F. Im not sure my manifold gets that hot! grin
My 1953 Chevrolet
1947.1 Gallery
what it cost for ceramic coating for 1 manifold?
1951 chevy 4400
Cost to ceramic coat one large 4 cylinder manifold about 2 years ago was $100, as seen here:
[IMG]http://thumb9.webshots.net/t/61/161/6/90/89/490069089gFXbnk_th.jpg[/IMG] [IMG]http://thumb9.webshots.net/t/60/60/0/94/1/490009401cXSSQn_th.jpg[/IMG]
The turbo housing cost an extra $50.
Grigg
---All pictures---
