2 members (Peggy M, MNSmith),
240
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37839 11/27/2003 10:39 PM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | so instead of spending 60 dollars at napa to buy a turning signal unit, i took one off an old 49 gmc 2ton. i was wondering if anyone knows of a place on the internet that has universal diagrams for hooking up these aftermarket turning signal units. the thing has a total of 8 wires coming out of it, so it gets confusing.
any sourses would be appreciated. murdoc | | |
#37840 11/28/2003 12:11 AM | Joined: Oct 2003 Posts: 23 Junior Member | | Junior Member Joined: Oct 2003 Posts: 23 | Maybe the guys at your locaL parts store will let you make a copy of the instruction sheet from a new kit....worth a try....usually five wire kits are for seperate turn light on the rear while seven or eight wire is for stop/turn combination ....
If all the cylinders ain't in a line it ain't cuttin it..
