Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, cmayna), 226 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#37839 11/27/2003 10:39 PM
so instead of spending 60 dollars at napa to buy a turning signal unit, i took one off an old 49 gmc 2ton. i was wondering if anyone knows of a place on the internet that has universal diagrams for hooking up these aftermarket turning signal units. the thing has a total of 8 wires coming out of it, so it gets confusing.
any sourses would be appreciated. murdoc
#37840 11/28/2003 12:11 AM
I
Junior Member
Junior Member
I Offline
Maybe the guys at your locaL parts store will let you make a copy of the instruction sheet from a new kit....worth a try....usually five wire kits are for seperate turn light on the rear while seven or eight wire is for stop/turn combination .... smile smile
If all the cylinders ain't in a line it ain't cuttin it..
#37841 11/28/2003 1:05 AM
Check here in the main page under electrical section. http://www.50chevy.freeservers.com
Joe
