2 members (Bill Hanlon, Steelonsteel), 131 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#378359 02/21/2008 9:00 PM
Small backfire burps when off the gas and going down hill....do I CW the dizzy for advance or CCW for retard....this one always cornfuses me? T/C Steve
yes
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Riding in the Passing Lane
If you turn the dist counterclockwise on a Chev. V-8 or 6 it advances the spark. I always go by which way the vacuum advance points. If it pops on deceleration it may have the idle mixture too lean or va vacuum leak.
1972 Chevy c10 Cheyenne Super
WHO ME?,
You turn the distributor CCW for advance. The rotor turns clockwise. To get the #1 plug tower to the rotor earlier, you must rotate against the direction of rotation....counter-clockwise. This advances the timing..makes the plug fire earlier! Make sense?
Stuart
I'll go with Wrenchbender on this. Sounds like a lean mixture to me which as he states can be a leaking intake manifold or carb base. A good place to start at least.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks for the help and T/C Steve
