1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | I'm pulling the motor out of our '49 6400. I have two bolts on a rear cross member that I cannot seem to get out. Does anyone know if there is some trick to getting to the top of these bolts? When I spin the nut on the bottom, the bolt just turns. I cannot see or feel the top of the bolt, it seems to be buried in the top of the rubber motor mount somewhere. Everything else is ready to go. Unless I come up with a better plan, the torch comes out tomorrow and I'm gonna cut those things out! Any other suggestions? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You should be able to find the top end of those bolts on top of the ears on the bellhousing. I've always been able to get them out with a little work.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sometimes you have to jack the engine up a little. The rubber is all walered out & is covering the bolt head or nut. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | The bolts look to be just a couple of inches long, and seem to die inside the rubber. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I don't know if they are any different from the ones on my 56 but they go through the rubber block and thread into the bell housing and the same for my 71. | | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | I got them, thanks. The bolt heads were buried in the rubber under 50 years of accumulated grime and road stuff.
The motor is out!.
Thanks for the help. | | |
