1 members (delky), 258 guests, and 3 robots.
Topics128,089
Posts1,056,141
Members48,436
#377207 02/19/2008 4:47 AM
1 Offline
Hey i was just wondering if anyone has ever turned thier AD hood into one that flips up from the sides like the older ones?If so how difficult was it.Ive always liked those kind of hoods and thought id try it if it wasnt to far off.
Might be difficult because of the way the nose curves down.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
look for a truck with that type of hood
32fire2 #377318 02/19/2008 3:15 PM
If there is a fairly long section down the center of the hood that is straight (flat) shouldn’t be too difficult. The straight (flat) section on my ’41 is about 35 inches long. This is where the hinge is. I suppose a slight curve could be accommodated for with some clever hinge mounting adapters. The rear pivot is on the top of the firewall and the front on top of the radiator support bracket. There is nothing in the hood’s curved area at the front. This area is entirely unsupported.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #377416 02/19/2008 8:14 PM
Ex Hall Monitor
Ex Hall Monitor
The side opening hood looks cool but it's a PITA to work on the front of the engine with one. If I wasn't so set on keeping Sweetie original I'd convert her to a front opening hood.
Tiny #377447 02/19/2008 9:28 PM
I am thinking you could hinge it right down the middle ( in the center). Then you could open either side or both. How would that look?
CFG61 #377477 02/19/2008 11:10 PM
Ex Hall Monitor
Ex Hall Monitor
That's what I'm referring to, thats how the older models were. It's a PITA to work on the front of the engine with a side opening hood. I had to pull the grill & radiator to change the timing gear housing seal. Not a lot of fun.
Tiny #377489 02/19/2008 11:39 PM
My old '54 Job Rated Dodge pickup was hinged in the middle. It wasn't hard to service. I wished it opened like a AD though.
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
How about setting it up like the early '50s Buicks? The whole hood could be opened up from either side and tilted to the opposite side, or removed completely.
Bill Burmeister
What if, instead of hinging it in the middle, you set it up like the old '50's Internationals? They had a combination hinge/latch mechanism on both sides. You could open it from either direction, and the entire hood would open up and hinge on the opposite side. To remove the hood entirely, just unlatch both sides.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Whoops!! Longbox thought of it first!
Rich
1947 Loadmaster
I had a 49 Buick with that hood. I hated it.
~Jim
1 Offline
yah youve guys really some good ideas. i was thinkin to have it like the older models where it hinged in the middle but have a hinge in the back and a latch in the front so the whole hood could still open.(ive been really thinkin about it drawing pictures in school tryin to think about what would be best)ive got a old hood layin around so ill be able to monkey with it a bit
if you have an old hood give it a shot, i think it might be hard or look a little odd, but hey why not give it a try you may turn it into something pretty cool
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
