2 members (carbking, TUTS 59),
108
Mod | | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Where might I find the flywheel bolt torque specs for a 235? Don't see them in any of the online manuals. (the ones that are currently working)
Thanks, | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Donf
Here are the torque reqt
======================================================================================== Torque specs are:
main cap bolts 100-110 bellhousing bolts 45-55 flywheel bolts 50-65 rod nuts 35-45 oil pan corner bolts 12-15 oil pan bolts 6-7 clutch pressure plate bolts 25-30 cylinder head bolts 90-95 manifold clamp bolts 15-20 manifold end clamp bolts 25-30 water pump bolts 25-30 spark plugs 20-25 fuel pump bolts 15-20 rocker shaft bolts 25-30
Ganesh | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Thanks! just what I needed. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | One more thing to mention is that the 235s had small plates that went underneath 2 bolts (3 total) with which you would bend up the corners against the bolt head so the bolts wouldnt back themselves out. | | |
