0 members (), 256 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#376907 02/18/2008 5:10 PM
i have a plan to make my 46 go, 261, orig drive line and patricks 3:55 conversion. Does me no good if i can't stop!!! want to keep the original brake sytem (origi-rod) i am building. another member suggested a "hydro-vac" booster and a dual M/C. i know nothing of the H/V system. the other option i have seen is the booster M/C combo for the 47-53 trucks. not sure if my brake syst will hold that pressure or if it will fit. anybody w/ any thoughts or experience. mechanicly i am ok, just new to these applications and equipment.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
bigedpa #377047 02/18/2008 11:08 PM
On the 3:55 conversionm are you talking about rearend gear ratio?If so that sounds like a good combination.I would definitly go with a dual master cyl.power if possible.I see so many guys fix these old vehicles up to go fast,and do nothing with the brakes.On my 55 I have a dual power setup with GM discs on the front,brakes work great.On my 65 which has a 500 Cu.In.caddy engine I have a dual Master cyl.with discs on the front but not power.This setup works good tooI went the easy route on the 55 and bought a Power master cyl. from Chevy Duty,that mounts right under the floor in the original position.
Apprentice
Apprentice
Im not to sure about the hydro vac system. Those are a pain even on vehicles that came equipped with them from the factory. Id choose a standard vaccum power unit. There are lots of different sizes available and they are much more simple to work with, in my opinion. good luck with whatever you choose!
You can't use a hydro-vac with a dual res master, you'll have to go with a standard booster.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
46 still uses huck brakes. Bendix brakes are a little bit more efficient than the Huck brakes. Regardless either system will work better with a power booster.
My preference was upgrade to go with 4 wheel disc brakes on my 1940 3/4 ton. 4 wheel drum brake systems without automatic adjusters are SCARRY! I can't tell you how many times the uneven grabbing of the drum brakes caused me to spin out of control in my 1st truck. It put me on the driver's side 2 wheels once while I was on the freeway... an event that I would not want to duplicate.
