3 members (Uncles51, Woodcmiami, Mitch4445), 53 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#362828 01/19/2008 4:32 PM
Hey i have just got a 1946 chevy 1/2 ton . The door hinges are badly rusted . What is the best way to get the pin in the hinges out ??
Its been years since I had a 46 but if I remember correctly I ended up grinding off the top of the hinge pin, soaking it with some Kroil and then using a punch was able to drive it out. You can usually drive them out from the bottom if you soak them real good...meaning a couple days but some are a pain.
Say..what part of S.C. are you from??
Edit: Forgot to say WELCOME to the Stovebolt page. Your in good hands now.
Achipmunk #362839 01/19/2008 5:30 PM
Thanks..Im from a little town Just outside of of Greenville called Campobello...next to the NC state line...It' just starting to snow here..I was hoping to get to play with my little truck today..Oh well guess I'll just stay inside and get idea's off the internet..
Hey, I'm in Boiling Springs. It can't be but about 20 miles from here. Give me call. Heck, there is enough of us stovebolters around here to start having a gathering.....mabye at the Beacon or up your way?...or here in B.Springs
Achipmunk #363013 01/20/2008 1:41 AM
Preacherson,
Welcome to the bolt! I just read in the latest issue of Classic Trucks on that very question to heat up and put some beeswax on it. The heat draws the beeswax in and lubes it up. Then just drive it out. When I did mine I used PB Blaster,tapped on it, let it set and drove out with a punch. They can be very stubborn. Have fun and good luck!
Dan
Chev4t6 #368604 01/31/2008 10:44 AM
Hey son i believe that driving them out from bottom is best as the top i think is Serrated .. both achip and chev4t6 have good ideas to loosen them up .Later Earl
GMC1937 #376394 02/17/2008 4:59 AM
The hinges on my 46 are in bad shape.the passenger side hinges were rusted so bad that when I finally got the door open ,the whole hinge instead of rotating on the pin..the whole hinge turned..no hope for them..is there any where to purchase new hinges..I have never seen any on ebay??
#376634 02/17/2008 11:35 PM
yeah the whole hinge bent...i worked with this hinge for a week..in the end there was nothing to do but break it off..both top and bottom was totatly rusted solid..almost as bad as being welded....no choice there..
Keith, try putting an ad in the Parts Wanted Forum and I'll bet someone will have one. Hey, you think you can make it to the clubs car show in Spartanburg in June?? I"ll drop you an email.
(I was just up your way last week!)
I don't have an answer to your specific question, but I know there are alot of guys here that do!
Welcome to the Stovebolt from another South Carolina Stovebolter! Good luck on your '46!! I live in Taylors which can't be any more than 15 miles away from where you are. wave
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Lucille #376745 02/18/2008 3:52 AM
Thanks guys....nice to know There is some stovebolters so close..I work in Taylors at the what used to be Steelheddle..its now GTP..we have a good machine shop there...i'm owed a few favors...maybe I can come up with something there as well..The clubs car show in june sounds good...maybe being around all them cool rods will get me cranking...all your help is appreciated..I just happend to stumble across this sight late one night...I love it....good stuff here...
